Component Switch box?
Discussion in 'General Video Gaming Chat' started by Willy, Jan 19, 2003.
  1. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Hi, I want to hook both my Xbox and my PS2 (and Gamecube when I get one) via component cables. Anyone know if I can do this? My TV only has one component input bit. Is there a switch box type thing available?
    Cheers.
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I ordered this from the US
    [​IMG]
    It does component and audio auto switching including digital audio. I've got it hidden away and it works like a dream.
    Bought it from copperbox.
    http://www.copperbox.com/
    Expensive but great quality.
    If you order from AudioAthority directly they will ship it with a UK power source. Otherwise pickup an argo job for a tenner.
    Neil.
  3. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Cheers for that.
    That's the only one I could find, but I was hoping someone may have found something a little but cheaper - it looks great and all, but $200 seems pretty expensive! It's for my Playstation 2, and for that sort of money I think I'll just have to make do with an RGB scart.
    Thanks for the help anyway.
  4. olaiho
    olaiho
    You can use a cheap AV switcher, like the one pictured here: picture
    Even though they are meant for composite video and l+r audio, they work just as well with component.
    They can usually be found at around 10£.
    Best Regards,
    Olaiho
  5. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Hmm, thanks - I'll take a look!
  6. richkeys
    richkeys
    Jan 16, 2003
    19
    London UK
    CHECK THIS SWITCHER OUT
    [​IMG]
    Allows connection of up to 6 different pieces of AV equipment to TV or display equipment
    Source equipment can be switched by remote control
    Saves wear and tear on equipment and interconnects
    Record between two different VCRs even if TV only has 1 Scart socket
    Record from DVD, camcorder or other AV equipment even if TV only has 1 Scart socket
    Comes complete with AV Hub switching unit, AV Hub remote control, 1.5m x Scart to Phono lead and 1.5m Phono to Phone lead
    Remote control requires 2 x AAA batteries, not included.
    Specs:
    Frequency range: 20Hz - 10MHz
    Input/output impedance: 75 ohm (Video)m 47 kOhm (adio)
    Input level: 1V p-p (video), 0.4V (audio)
    Insertion loss: 0.6db
    Remote control range: 25 feet
    Dimensions: 290mm x 185mm x 53mm
    Weight: 1.2kg
    £ 35.25
    (£30.00 + VAT)
  7. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Just beware that if they don't support 75ohms you will run into picture quality issues and you will stuggle to get a decent progressive or HDTV picture. Some work ok to a point [i have a madcatz box that does progressive but its snowy/ghosty].
    Regards,
    Neil.
  8. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    Thanks to both of you for your help. Looks like I may not have to spend huge amounts of money after all!
  9. Erpland
    Erpland
    do people think that component is going to be the common way of connecting video in the future in Europe?
    So simple, robust and should be cheap way of doing it, Ive always hated scart leads and just recently bent some pins on an s-video cable.
    I see DVD players and consoles now with component leads, my TV is imported from Australia and comes with component but no scart, I hope to get a projector eventually and enjoy the ease of component on that also.
    Apparently ATI where going to do it on their new cards, or have they already?
  10. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    They have it as an option, and yes I hope it becomes the standard atleast in the UK.
  11. Matravers
    Matravers
    Jan 26, 2003
    184
    16
    north london
    Olaiho
    Could you please tell me where to get the switcher from and if it works ok, ie...can you see any quality loss on the picture of anything going in.
    I want to use an xbox and dvd thru component and if this works well it will be fantastic!!!!!
    Also, does a console picture really look better thru component in your experience?????
  12. Matravers
    Matravers
    Jan 26, 2003
    184
    16
    north london
    richkeys
    I am sorry to reply so late to thread but could you give me some more info on the letsautomate switcher that you posted......is it any good and do you lose any picture quality.
    Price seems to good to be true.
    I would really appreciate your assistance
  13. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Unmodded PAL consoles only output DVD in 480i resolution.
    Regards,
    Neil.
  14. Willy
    Willy
    Jan 4, 2003
    466
    19
    Bedfordshire
    In case anyone is searching for this, I finally got this set up last night. I got this video switch box for £30 from Keene electronics: (http://www.keene.co.uk/cgi-bin/codesearch.pl?SVS14).
    I have hooked it up to my TV with a Thor component cable and it works perfectly. XBox & Gamecube (US ones) are running progressive scan just fine with no reduction in quality (as far as I can see on my 32" Tosh Strata anyway, don't know if that would be the case on a big plasma).
    Hope this helps...
