Component Switch Box ?
Discussion in 'Cables & Switches' started by rickyroma, Mar 18, 2005.
  1. rickyroma
    rickyroma
    Jan 15, 2005
    936
    Dublin
    +70
    Hey
    looking to hook in a few devices to the one component slot on my PW7 Plasma , 3 would be ideal , xbox, dvd player & ps2.
    Done some digging and found auto boxes which cost a good bit and manual boxes , which dont cost so much.
    Just wondering if anyone has had any experience with either types and which would be best ?
    I hope to be using all gold connections throughout !
  2. Flimber
    Flimber
    Sep 22, 2002
    13,723
    Yorkshire
    +4,484
    The Audio Innovations 1154A and various Zektors have both been discussed around these parts. Do a search on 'em.
    Mike.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,572
    rickyroma
    The Zektor boxes HDS4 (4 In 1 Out) and HDS4.2 (4 In 2 Out) are not 'Auto' though once programmed to respond to IR commands they pretty much disappear into your AV set up.
    See http://www.zektor.com
    There are a lot of AV Receivers that will handle three YUV sources - this may be another area to consider if your not 'attached' to your current Amp/Receiver.
    Best regards
    Joe
  4. shaithis
    shaithis
    Feb 25, 2005
    1,668
    The Last Aerie
    +31
    Extremly happy with the Audio Authority 1154A here :smashin:
    Relatively expensive but I cant notice a signal difference and it does digital audio as well.
    Only problem I had was the US PSU blew up within 2 mins of plugging it in, replaced it with a new UK one from Maplin.co.uk and all has been fine.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,927
    The Borders
    +3,572
    Hello all
    Just a quick note to say the Zektor products are CE approved for UK/Euro sales and supplied to UK/Euro customers with the relevant factory sourced power supply.
    Best regards
    Joe
