Quantcast
Component- stupid question
K
kace
I'm thinking of buying a component cable for my DVD to plasma. Does a component cable carry sound as well as video in a similar fashion to SCART?
Joe Fernand
AVForums Sponsor
Kace
As Ian J says in general a YUV Component Video cable is 3 x RCA (Phono) to 3 x RCA (Phono) for video only.
If your using the speakers on your PlasmaTV as a back-up to an AV System you could get a five core Multicore cable that will carry YUV Video + Stereo audio. I wouldn't normally use this cable on a high quality audio system but for use with your plasma speakers it will be fine.
Though you may find if you have 3 RCA inputs for YUV on your Plasma you still have to retain a SCART cable from your Source to the Plasma for Audio.
Best regards
Joe
jamiev
go for QED cable if less than 2m, best quality you can buy!
:thumbsup:
Ian J
If you discount all cables that don't begin with the letter Q you could well be correct
