Component splitter
Discussion in 'Cables & Switches' started by thfccambs, Nov 2, 2004.
  1. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Am looking to run my x-box into my plasma by component(hi-def tv).Already have my 575 dvd player on component at the moment.Would a component splitter lose any quality in the picture?Anyone got a links to a good component splitter?
    cheers
  2. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    So no one uses a componet swicher then?
  3. mr ooops
    mr ooops
    Mar 4, 2003
    3,657
    103
    Hardwicke and Wotton
    +349
    i think most people use there amp where its got 1 component in and 2 or 3 out...... me i just use my feet and hands and change the cables when needed
  4. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,351
    Glasgow, UK
    +1,312
  5. thfccambs
    thfccambs
    Jul 17, 2002
    23,968
    White Hart Lane
    +6,898
    Cheers lyris,at that prtice i would be better off buying another component board for my PW7.
  6. Pikman
    Pikman
    hunts, I may have some RCA Y splitters for sale soon. They're audiophile quality and machined from a solid block of metal to keep signal loss to a minimum.
    I got them from America but am looking to buy a surround processor with multiple component inputs - hence the sale. I'll try and find a link so you can have a look at them or even orde rthem brand new from the website.
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    hunts1uk
    Its a Component Switcher your after - not a splitter; you'd require a splitter if your were trying to share a single source with two or more displays.
    Decent quality Component switchers are few and far between - we import the Zektor range to the UK. These offer you 4:1 and 4:2 switching with IR control for YUV + Stereo or Digital Audio; they are very good though as you say more costly (SRP £240) than a second TY-42TM6AB Input board (SRP £82.25).
    See http://www.zektor.com for more info.
    The HDS4 and HDS4.2 act like learning remotes - you teach them to react to the IR Input selection of your AV Amp; saves you having to switch input selections on your Amp plus your Display.
    Best regards
    Joe
  8. iangilroy
    iangilroy
    I'm looking for something similar - I need to switch between 3 RCA component inputs. This might be a dumb question but couldn't I just use any other reasonable quality RCA switcher? I might need to use two - say two audio switches - but I guess this would work?
    Otherwise, I'd sooner put £240 towards a replacment amp :)
  9. Supra
    Supra
    Dec 12, 2002
    433
    Kent
    +14
    I didn't think there were many amps, especially in that price bracket, that output component, most are S video. I could be wrong though.
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    iangilroy
    Apart from the obvious limitation of having to start 'selecting' inputs on two or more non IR controlled devices and having ugly looking switches 'on show' there are plenty of technical reasons why your first 'option' may not be an ideal solution for everyone - though if your on a tight budget and don't have a large monitor it may well be viable for you.
    Putting your cash towards a decent quality AV Receiver with on-board video switching is viable - though again remember not all switches are created equal; there are plenty of AV Receivers out there that have far from 'clean' video circuitry; the Zektor kit has passive switching to minimise any signal loss.
    Lots of acronyms and figures but worth a read if your interested - see http://www.zektor.com/support/componentvideo.htm
    Best regards
    Joe
  11. iangilroy
    iangilroy
    Joe - thanks, that's pretty much what I thought.
    I've been thinking about a Denon 2805 or 3805 for a while now - do you happen to have any idea about the video switching quality that they offer? The output would be plugged into a 42" Viera so not degrading the quality is definitely important.
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Ian (being presumptuous)
    We've supplied/installed plenty of the AVR-3805 without problems - the AVR-2805 I'm not so sure of but that's only because I haven't used it so far.
    The Digital Audio Delay, Video signal conversion (Composite and S-Video to YUV for secondary sources) and the semi auto Surround Sound set-up routines of the AVR-3805 are certainly worth a mention too.
    Best regards
    Joe
