Component/Scart/RGB/S Video.... which do I use?
Discussion in 'Plasma TVs Forum' started by lennyg, Nov 28, 2003.
  1. lennyg
    lennyg
    Can someone please explain the differences or post a link to show me what the above do and which options are best for my about to arrive Th42PA20 which has various connectors on the rear , with different scarts showing different varities of input on each AV channel.
  2. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    If you do a search there are literally hundreds of posts on this subject.
    In summary, in terms of quality they are, best first:
    Component (progressive scan)
    RGB (although some people claim it is superior to component but it does not have prog scan capability)
    S-Video
    Composite
    Scart is a physical connector which can output various signals - RGB, composite, etc.
    If you have component sockets, use those - assuming of course your feed (e.g. DVD) has component output.
    If not use the Scart RGB input.
    Failing that you can use S-Video.
