**Component>SCART - Any better than SCART>SCART?**
Discussion in 'Televisions' started by GodtheDJ, May 24, 2003.
  1. GodtheDJ
    GodtheDJ
    I have a Toshiba DVD player that has component video outputs on it. My question is, if I connect it to the TV via a component>scart lead will this offer any picture improvement over the standard scart>scart leads?
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Please post your TV make and model and DVD player model and also where you're located. Someone should be able to help you then ;)
  3. GodtheDJ
    GodtheDJ
    The TV is a Philips pw6006c, dvd player is a Toshiba sd200e. I am in the U.K
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Hi there, your TV can't accept component video signals, so what you suggest wouldn't work. Your best option is the one that you're using: RGB via SCART :)
  5. GodtheDJ
    GodtheDJ
    Yeah thought it might be pushing it a bit. I may well invest in a decent IXOS scart though. Thanks
