Component/RGB On TV
Discussion in 'General TV Discussions Forum' started by Gerry, Nov 12, 2001.
  1. Gerry
    Gerry
    Oct 20, 2001
    251
    My Gaf
    +10
    The tech spec for my aconda tv states it has an "RGB-suitable/input ready component video" Euro AV/Scart connection. I had thought RGB and component were two separate connection types, RGB via scart and component via phono type connectors. As I have never used either before I'm not exactly sure about it in practise. Can someone tell me what the above statement(in "") means and how to utilise it in a practical way.
