Component Question
Discussion in 'Cables & Switches' started by 54xhg, Sep 15, 2005.
  1. 54xhg
    54xhg
    Feb 6, 2005
    I've just got the sony hx510 dvd recorder.If i connect it up to my tv(hitachi 32ld7200)using the component cable do i also have to connect a scart cable to my tv.
    Thanks.
    54xhg.
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    no, but you may have to switch component on in your dvd set up
  3. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    not unless you tv has built in freeview, then you would need to send the free view channels to your dvd recorder via scart, but having done a quick search on your model it seems it does not
  4. loadsofleads
    loadsofleads
    No need for Scart, but you will need seperate audio connections, component is video only.
