Component Quality
Discussion in 'General TV Discussions Forum' started by gtfc, Jun 25, 2002.
  1. gtfc
    gtfc
    Can anyone give me their views on the improvement in visual quality from an RGB Scart to Component connections assuming good quality cables. I'm looking at a 28ZD06B Tosh against a Panny TX28PL10. Will I see a better picture with the component Tosh over the RGB Scart Panny from any DVD with Component out ?
    Many Thanks
    John
  2. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    Opinions vary between component giving a marginal improvement over RGB SCART, to none at all. Some even say RGB is better. If the Tosh could take progressive scan it would be worth going for the component, but as it is I wouldn't base your choice on this.
    RGB SCART into a Philips pixel plus, now there's a hell of a picture.
