Component PS2 on a plasma?
Discussion in 'Plasma TVs Forum' started by Planet__, Sep 24, 2003.
  1. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    I'm a bit confused :confused: , but no surprise there!
    After spotting on another thread that there is a 'component' lead for the PS2 (see the picture below), I'm wondering does this go straight to the component terminals of a plasma? Or does the signal have to be converted?
    [​IMG]
    I know it's RGB, but is it YPbPr? I doubt it as surely a Sky signal is RGB and that needs to be converted?!!
    Then how about this as a method of connecting it to a plasma, using it's VGA port?
    [​IMG]
    The above is only an example as there are other types available. Anyone tried it with a plasma?
    I think it's time to get my crayons out again! :D
  2. Labrat
    Labrat
    The lead goes straight to the plasma component inputs.
    Go to the PS2 setup screen (boot it without a game disc) and you'll find an option to set its video mode to either RGB or YPbPr. In this case select the latter, the default is RGB for SCART video leads.
  3. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Cheers for that Labrat! You just won me the bet!
    Question though, if you connect it up and it's RGB'ing, can you see anything on screen to be able to change it to YPbPr? Does it save this setting, or do you have to change it everytime?
  4. Labrat
    Labrat
    Yes to both.
    If you have the wrong mode selected, the display is visible but the colours are wrong. Settings are stored in the PS2 itself (not the memory cards) and are persistent.
    There are also a small number of games (Tekken) which support progressive scan on plasmas.
  5. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Thanks again Labrat!
    Component it is then!
  6. Nick Laslett
    Nick Laslett
    Oct 9, 2002
    The image quality using the component leads with the PS2 is stunning. Even better than RGB Scart.
  7. Planet__
    Planet__
    Aug 27, 2003
    292
    Wiltshire
    +10
    Thanks Nick!
    I'm so looking forward to playing GT3 in 42"! :D Split screen mode shouldn't be so much of a pain to use either.
  8. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    344
    16
    Whatever you do, don't use that Redant box. It's awful!!!
