component prog scan from pc ?
Discussion in 'Projectors, Screens & Video Processors' started by robwight, Jan 28, 2004.
  1. robwight
    robwight
    is there a card that sends out pal and ntsc progressive scan through component connections ,playing a dvd /hq avi from the hard drive to the tele ( 57wh36 rear pro ) which has prog scan..
    if so what price do they start from /
    also what about a pc card that has rgb if above is a no go.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    The VGA output from a PC is RGB AFAIK, you just need the right cable, never seen a component output as in Y/Cr/Cb/whatever.
    PC output is always progressive via VGA or DVI unless you select a specifically interlaced refresh rate.
    Radeons and nVidia cards are all multi-format AFAIK, my Radeon can be selected for NTSC or PAL output via the drivers, cheaper ones have a jumper, though I've never bothered trying to use them in NTSC mode.
  3. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    With PowerStrip one can even select "interlaced" output!
    StooMonster
  4. robwight
    robwight
    I have a gforce xt5600 just now which has a svideo out to the tele which looks great , (for films etc ) but the normal screen/windows is understandibly pants.
    so if theres a lead i can buy that will go from vga connection to component in on the tele that will be great,and it will be progressive ?
    hope so !!!
    let me knwo anyone
  5. RAMiAM
    RAMiAM
    May 24, 2002
    481
    UK, Kent (nr Ashford)
    +9
    I'm pretty sure the ATi All-In-Wonder cards have the capability of outputting component.
    RAMiAM
