Component problems with PW7
Discussion in 'Plasma TVs' started by theredstar, Feb 23, 2005.
  1. theredstar
    theredstar
    Dec 16, 2004
    65
    My PW7 (and media box) was delivered today from AV sales, and so far so good. Everything works except for a problem I'm having with component input.
    I've got three component devices going through a switcher - an X-Box, a PS2 and a Panny E55. The X-Box is fine _ I've changed it to 480pp and the PQ is stunning.
    However when I switch the PS2 or Panny on, I can hear sounds, but the picture is blank. What am I doing wrong. I've checked all the cables and they're all plugged in securely, so it's not that.
    The only difference I can think is that the Xbox is outputting in 60Hz and the other two in 50Hz. Can you not get component in 50Hz?
    Also I've had problems getting the 2nd Scart to work. My PVR goes through no.1 and that's great, but when I plug a games console or DivX player into 2 (or 4) nowt happens?
    Any ideas?
  2. tamthetim
    tamthetim
    Nov 7, 2004
    478
    Perth
    +6
    Have you cahnged the menus on the PS2 and recorder to output component?
    Cheers,tam
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    also have you tried direct to media box from device
  4. theredstar
    theredstar
    Dec 16, 2004
    65
    I'm not sure how to alter the Panny DVD recorder to output component. I sort of assumed it would do it automatically. Do I take it that it doesn't?
    HD Yep, I've tried direct to the media box and the same result. I know your opinion of cheap splitters, but I must say I'm well impressed with 480pp from the XBox. Does anyone know if the Panny supports 720pp?
  5. theredstar
    theredstar
    Dec 16, 2004
    65
    Plus, if the Panny's connected via component and I can't see the picture, how do I alter the settings? Reconnect via Scart?
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    yes use scart to change settings both DVD and PS2 will need to be set to component (YPbPr/YUV ouput) will be in settings of Both, for PS2 turn on with no Disc in and go into system, settings
