component plugs
Discussion in 'Cables & Switches' started by garyc, Mar 31, 2005.
  1. garyc
    garyc
    Dec 21, 2002
    866
    Jersey, Channel Islands
    +13
    Silly question this really, but when you want to run lengths of component cable in partitions etc, so space is tight, but is the idea to run un-terminated cable then put plugs on afterwards?
    If so whats recommended?
    cheers
    Gary
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Use RCA/phono plugs, should be available from electronic (components) stores. Keep in mind that you should use video cable, i.e. cable with 75 Ohm impedance, for best results.
