Component outputs......
Discussion in 'Satellite TV, Sky TV & FreeSat' started by nik_fatw, Oct 9, 2004.
  1. nik_fatw
    nik_fatw
    Feb 1, 2004
    5
    :lease:
    I have been searching to buy a freeview reciever with component outputs as the scart RGB's are not compatable with my "Yamaha DSP Z9".
    I have tried a "Keene" converter, however there is too much signal loss.
    Does anyone know of a Freeview reciever with component out?
    I also have the same issue with my NTL digital box, NTL have told me they dont make one with component out.........!
    Are there any NTL compatable boxes with component out available to buy?
    Many thanks,
    Nik
    x.
    :hiya:
  2. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Nik,
    Maybe try the JS-technology RGB to Component convertor. A quality product that should give better results than the Keene.
    Or try a Nebula DigiTV Freeview card in a PC with a radeon graphics card with the Radeon component out dongle ( if this will work at the resolutions you need etc)
    Good luck,
    Mark.
  3. bferbrache
    bferbrache
    Apr 26, 2003
    1,865
    48
    Leicester
    +99
    Netgem I-player outputs component video.
  4. nik_fatw
    nik_fatw
    Feb 1, 2004
    5
    :confused:
    I have looked at the rear connections on this model....I was able to find the rgb scart connections but no rca component connections.
    Does the setup have the capabillity to change the signal within the scart from RGB to Component?
    Thanks Nik
    x.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    The Netgem can be configured to output YUV component via the scart socket.
    I would suggest trying the JS-Tech converter as I have been useing one for a while with Freeview and the picture quality is excellent. Although not the cheapest at £145 they are the best available and I think are the only option for your NTL box. JS-Tech also do a scart switch so you could get the converter and switch boxes and put Freeview & NTL through the converter and save the cost of buying another Freeview box.
    Mark.
  6. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    Like Mark I use a JS-Tech converter to get a component signal from a Freeview box. I have a LG LCD 30" monitor which has component but no scarts. Picture is really great, and highly recomend JS. No auto aspect ratio switching of course; which is an inconvenience.
    Richard
  7. Ultra2man
    Ultra2man
    Dec 19, 2003
    1,104
    2
    Biggleswade, Bedfordshire
    +245
    Couldn't you just feed the s-video output to the amp And let it upconvert the input to component out.
    That might save you buying extra cables/boxes.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    Yes you could let the receiver do upconversion, but you would be loosing PQ as this just converts the signal type but does not improve it. RGB/YUV signals are nearly always better than S-Video. This option would be ok for a stop gap if funds are tight, but if you do have the money available then you do want to get an RGB>YUV converter to keep the best possible PQ.
    Mark.
  9. guli
    guli
    Sep 3, 2004
    412
    16
    markE,
    How can you "improve" a signal? If you mean provide a cleaner YUV signal, that's correct.
    We must not forget that any conversion would not claim back lost information thrown out.
  10. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    But a good video processor can do wonders to a picture - I know, I've got one :clap:
    Mark.
  11. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    AV amps upconverting? eg s-vid in coverted to YUV out. I hadn't realised they did that, I assumed s-vid in would come out on the s-vid out lead. Do most makes do this, or only certain makes and models?
    This gives me a whole new set of things to think about!
  12. cinesom
    cinesom
    Aug 30, 2004
    30
    www.scancom.ltd.uk RGB to component converter CSY 2100, works well - look under format converters - 75 quid
  13. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    I think most makes of AV receivers now do upconversion, but certainly not on all models. You will need to check the specs closely if you want/need this feature.
    Mark.
  14. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    At the moment I'm going to connect each source directly to my pwd6. I've probably got enough inputs not to worry about getting a up-converting amp just in case. I'll ask my further questions in the amp forum.
  15. Ultra2man
    Ultra2man
    Dec 19, 2003
    1,104
    2
    +245
    Edit sorry Jim, I didnt read the top post correctly as you werent the sender of it.
    Jim,
    you said in your post at the top of this thread that you have a Yamaha DSP Z9. I'm pretty sure that this amp upconverts any type of video signal in to component out. I'm not saying that you will get an improvement in pic quality but if its the model I'm thinking of doesn't it also have a built in scaler that will match the resolution of your Plasma ?
    Mike.
