Quantcast
Component output video cards
andyr300
how do i know whether my GFX carda can output YUV from the VGA port?
or does anyone know which cards can do it?
KraGorn
Unless it has an adaptor or converter (both ATI and Nvidia cards are available with YUV capabilities) then it can't, VGA outputs are always RGB.
baldrick
I bought a NVIDIA 6600GT card for it's component out capabilities, but it's causing my problems!
At first I thought it was an issue with the breakout cable but the replacement cable appears to have full connectivity yet I'm still getting greyscale images. I haven't had a proper play with it though, I need to do that and try to isolate the problem!
andyr300
where could i purchase a convertor/adaptor?
motile rod 2
Try ebay. Or ask around nicely and someone might sell you there spare one considering most people don't use it.
edit - sorry, that's only for cards that actually support component out and have the necessary extra pins on the TV out. Firstly what graphics card is it, model and manufacturer?
baldrick
I've had another play with my card but to no avail. I worked out that the new breakout cable had a different pin configuration to the original so I re-wired and still no joy!
I can only assume that it's the socket on the card that's causing the problem so I've contacted Scan...
I know PC VGA to component doesn't work, but what about DVI to component?
I've also seen that Gigabyte are releasing an HDCP card that comes bundled with an HDMI to 'HDTV' cable, and I'm sure that means component?
spuddler
Hi,as far as i know D-Sub/VGA(RGB),Scart RGB,component(YUV) & S-Video etc are all analogue signals.DVI-D or HDMI are/carry digital signals(DVI-I can carry analogue as well thou,RGB,it as extra pins for this).
Cheers BOB
ps I would have though the less conversion/processing you can have in the chain before final output to the screen the better.Also would have thought only convert/process if its the only way to connect/input to the device you want to use.
motile rod 2
That should be ok, but double check your tv out has the extra pins. Try ebay for the adaptor or ask around here.
andyr300
i have no idea,how can i check the manafacturer,i cant remember from when i bought it.maybe leadtek but cant be sure.
motile rod 2
Just look at the tv out on the card and compare it to a standard s video cable. If it is exactly the same as s video with only 4 pin holes then you can't use the component adaptor. If it has more, 7 pin holes I think, then you can use the component adaptor.
lazysod
9 pins on the component out adapter.The easiest way to check is to open her up and check the serial No and then a Google should get you the answer.
andyr300
looks like 4 pins to me,where can i pick up the cheapest card that will do component out of the box?
andyr300
thats cheaper than i was expecting,will it come with the component box thing i will need?
also,will PQ be on par with using the VGA?,as i only want to use component to get it at 50hz,im having trouble with the VGA at 50hz!!
motile rod 2
Good card that one. A few people have had trouble getting the component out to work on a number cards though, just a heads up.
The component adaptor will come in the box.
andyr300
outputting to a Panasonic TH42PWD8
at 50hz,the picture comes up so far to the right,i dont have enough adjustment on the screen itself to centre it, and MCE on start up switches the refresh rate upto 75hz which is annoying.
when i force it in powerstrip, i can centre it and the PQ is great, but the sound goes progressively further out of sync as MCE runs.
lazysod
I don`t know about Plasmas I just know I haven`t found an LCD that accepts 50Hz from a PC so I can`t answer that. I have run VGA out at 1:1 pixel mapping and the TV picture from my Media Centre is no better or worse than component out at 720P.
andyr300
i think i might try this component output lark,to see if it helps me out.
does it have seperate settings in the nvidia software?can i still run dualview or will i have to use clone??
andyr300
ok, thats cool. i will prob give that a go then.
...and be really annoyed when it still doesnt work like i want it too!!
andyr300
im just hoping vista will be a bit more PAL compatible,seems to be built for NTSC really.
can but hope...
andyr300
something amazing has happened.just upgraded to the HD beta drivers,and now it seems to be sticking at 50hz and it fits the screen perfect...and MCE isnt changing the refresh rate...just need to check everything is in sync for a lil bit and hopefully the set up will be perfect
Similar threads
Trending threads
Latest News
Disney+ UK launch now 24th March
  • By Andy Bassett
  • Published
LG Filmmaker Mode will use autosensing
  • By Andy Bassett
  • Published
Hisense U8Q and U7Q QLED TVs coming to UK in 2020
  • By Andy Bassett
  • Published
AVForums Podcast: 20th January 2020
  • By Phil Hinton
  • Published
