Component out problem with Pioneer DV-747
Discussion in 'Blu-ray & DVD Players & Recorders' started by 7MAT, Sep 18, 2003.
  1. 7MAT
    7MAT
    Sep 8, 2003
    168
    SURREY
    +8
    Tried to wire up my Dads Pioneer DV-747 via the component out to view on his PDP-50HDE.
    Went into the DV-747 set-up menu and changed output to component interlaced, but no picture?
    Read the manual several times and can honestly say I think it is set-up correctly.
    Are there any known bugs with component out on the DV-747?
    7MAT
  2. loonatic
    loonatic
    Jan 4, 2003
    1,877
    41
    Springwell Village, Gateshead
    +16
    Have you set the Pioneer's AV3 input to component/YUV also ?
    Cheers, Lee
  3. 7MAT
    7MAT
    Sep 8, 2003
    168
    SURREY
    +8
    Yes the Plasma is already using AV3 imput switched to component as we are using a VSA-AX10 AV amp.
    When you switch the DVD player on you get the pioneer logo come up for about 1 second then it goes blank again.
    Forgot to mention that the player has the full Techtronics region mod + PAL progressive mod.
    7MAT
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Have you tried resetting the player back to factory defaults & see if that helps ? (It's in the manual ......swtching on while holding in the stop button or something like that) I have heard others speak of this helping when they had problems going from interlaced/progressive settings.
