T
thecheekymonkey
ok, got an lg rz plasma, happy with it for what i paid for it.
anyway, heres the dilema if you could call it that.
on my set up, i have my xbox going to HD adanced AV box, which give component out, this connects to the component in on my plasma.
i also have a panasonic dmr e85 dvd player, which also has compnent out, and i would also like to input this into the plasma.
dont want to get a component switcher.
would like to use a converter / cable adapter to allow the component to either the VGA in, or DVI in.
on a budget, , any suggestions of where , and what i need (i`m in the uk)
i have done a bit of searching, but seeing as this is by far the best AV forum going, thought i`d ask a bit of advice here
cheers for the help
cheers for the help
