component or scart
Discussion in 'Plasma TVs Forum' started by clarkesville, Apr 26, 2005.
  1. clarkesville
    clarkesville
    Apr 14, 2005
    101
    19
    Birmingham
    Having decided on getting a Panny TH42PW7 in black, can someone please help me in the best way to connect my sky plus and my arcam dv79 dvd player . May sound a silly question but all a bit new to this stuff
  2. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    i'd say RGB Scart for sky and component for dvd (or hdmi if ya can get a hdmi board fert pw7)
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Arcam via component (do you have an AV amp?) and SKy+ via either via Scart to scart board (not best) JS RGB>VGA (my preference), JS RGB>YUV via AV amp, or S-video direct to AV amp (either converted by amp to component or fed into panel S-video, great idea for saving costs, but not the best long term)
  4. clarkesville
    clarkesville
    Apr 14, 2005
    101
    19
    Birmingham
    Yeh AVR 250 AMP IF THIS HELPS
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Arcam AVR 250? does this switch component video? I doubt it converts S-Video either so a componet board and Either the JS RGB>VGA or JS RGB>YUV if the amp switches component
  6. pa 28 driver
    pa 28 driver
    I have just been into a certain Hi - Fi shop to get cables etc for my new sony having installed tomorrow & they have said best way is to use s-video and component re sony plasma/sony surround system with dvd/sky plus. No scart lead they said if you want the best connections.......now confused :confused: I would have thought first thing would need would be scart but they say audio/optical leads way to go....but what do I know, apart from they cost £130!
  7. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    should of asked them to show you a display connected via svideo and display connected via RGB scart and then you pick the best...
