Component or S-Video??
Discussion in 'Plasma TVs' started by Desiboy501, Sep 26, 2004.
  1. Desiboy501
    Desiboy501
    Sep 26, 2004
    20
    I recently got a Panasonic TH42PE30B plasma but believe it or not, its still in its box!! (have'nt had time to set it up!).
    Now......im using DVD and Sky+ as my sources. Both these devices have component inputs. My plasma only has one component input. Which source shall I use to put into the component - DVD or Sky+??
    For DVD, is S-video or Component better??
    Thanks in advance
  2. DucatiEVO
    DucatiEVO
    Component is better than S-VHS and also allows progressive scan!
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Sky+ as standard does not have component outputs.
  4. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Scart for Sky +, component for the DVD.
  5. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    I think you may be confusing component for composite. Both analogue signals but on the opposite sides of quality to one another.
    Component is much better quality and is the connection with 3 phono plugs coloured Red, Green and Blue. As Hornydragon said, Sky + does not have this, but it can be connected via scart set to RGB which gives an on par performance. Your DVD player is more likely to have the component out for the best transfer of pictures.
    On a plasma composite signals (single yellow plug)tend not to look good which is probably why there is only 1 on your screen.
