Component or S-Video to RGB
Discussion in 'Projectors, Screens & Video Processors' started by Nic Rhodes, Mar 24, 2001.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Does anyone know a little box of tricks (<£100)that can do Component or S-Video to RGB.
    This would need to be interlaced not progressive. I want to take the interlaced output and try to get it into a Scart (via RGsB or RGBH).
    I am sorry if this sounds a funny request but there is method in my madness.
    Thanks for any help
  2. Rob
    Rob
    Jul 17, 2000
    1,286
    Norwich
    +35
    Hi Nic.
    Lektropacks (08700 711911)do a video format converter . Its £199 though so might be too much. You could also try Keene Electronics (01332 830550.) The only other ones I know of are more expensive still. Key digital and One progressive labs make some good units. Your best bet might be to do a search on the TAW and AVS forums.
    Cheers Rob.
