khiladi4you
Will i see difference if i use Component for SD satellite receiver over RGB Scart on HDTV?
Only Sky HD has component outputs for connection to a TV or monitor. Sky+ has S-Video in addition to RGB via Scart, and the SD Sky box only has RGB over Scart. All have composite out over scart, but that's the lowest of the low as far as quality is concerned.
I think it depends if the component out will be higher than the "SD" PAL that Euro TV's have, and also whether it will do progressive component. In either case you will see an improvement over RGB Scart. Can't say by how much it will be improved, but it will be better!
