Component or DVI-D?
Discussion in 'LCD & LED LCD TVs Forum' started by AllyJo, Feb 8, 2005.
Tags:
  1. AllyJo
    AllyJo
    Feb 8, 2005
    62
    Which one is better or is it a very small difference?
    I am getting some Comp cables to connect my Denon 550SD DVD to my new Philly 9986 32" tonight, just wondering if its worth going the full DVI-D with perhaps the Denon 1910 to the tv, which do you guys think would be better to show off the Philips picture best and is it worth changing now if the diff is small?
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,031
    41
    dat london
    Personally at the moment, no.
    There might be an increase in PQ with an upscaled image but the 1910 is apparently affected by macroblocking (Blocks of colour in the backgrounds). I'd suggest waiting another 6 months maybe for the next batch of DVD players with upscaling to be sure of quality.
    Or, go and test it yourself and get a 1910 from your local bod with a good returns policy.
    Richie.
  3. AllyJo
    AllyJo
    Feb 8, 2005
    62
    thanks Rich Ill let you know I needed a new DVD anyway so ordered a 1910, ill try both if there is no diff ill use the new player in my other room where my dvd of some 7 years has finally gone kaboom!
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    AllyJo,
    You'll find that the 550 does a fantastic job through the component/VGA/DVI adapter. Super smooth images.
    Jimmy
  5. AllyJo
    AllyJo
    Feb 8, 2005
    62
    thanks Jim cant wait till i get home :thumbsup:
    Question I thought the DVI socket on the phily was DVI-D its DVI-I apparently is this ok to use with the new HDMI Sky setup?
  6. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Yeah, sure is!
  7. AllyJo
    AllyJo
    Feb 8, 2005
    62
    sorry to keep boring you Jim, any point spending a lot on the component cables going with the cables that came with the TV i.e the comp/vga/dvi stuff? or a usual 10pound set ok?
  8. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Two Jims on the go here AllyJo!
    I am using a very nice component lead that I got from www.tvcables.co.uk for £8.99. Really nice quality and perfectly adequate as the Philips adapter is the weak ling in this setup. Having said that, it works very well.
    Jimmy (as opposed to Jim)
  9. AllyJo
    AllyJo
    Feb 8, 2005
    62
    hehe thanks again Jims and Jimg :clap:
  10. EffTee
    EffTee
    Jan 20, 2002
    196
    Bristol
    +5
    I used this company to get a component to VGA cable - Beststuff - that my Dad is using on his set. It's very good quality for the money and was despatched promptly. I think the original pointer to them came from this site, can't quite remember.
    It's a lot tidier than the standard setup. Obviously you still need to use the VGA to DVI converter. It's the purple one one the site, but is actually a more tasteful blue in the flesh.
    EffTee
