Component on the Samsung SP50L7HX
Discussion in 'General TV Discussions Forum' started by AndoverRed, Sep 21, 2005.
  1. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    I was just playing about with an SP50 in Curry's this morning. Unfortunately, I was not able to view anything via the component input, just the SCART and RF, still impressive though.
    I am very interested in this display as it looks the business. However, I have heard that the component input has issues. I would intend to connect all my AV devices (Arcam AVR300 & DV27a, ntl set-top box, and x-box) via component.
    Any comments?
    The default settings are a tad high aren't they? What are the recommended settings for this display?
    Mark
  2. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Never heard of an issues with component, i use component as well as hdmi and the results are impressive on both though i had to change some settings for hdmi. The results off component are excellent.
    I'll post my settings later but if you do a search there has been settings posted previously. :smashin:
  3. jdslater1
    jdslater1
    Sep 4, 2005
    889
    28
    chadwell heath
    +39
    Please post your settings soon br14n, I'm getting desperate! I have the same set but the 950 player. Just bought component cables on the advice of Kableman and everytime I take the HDMI cable out, I cannot get the picture back (I switch it over to P-scan take the HDMI out and then its gone!). At the moment I am finding it very hard to be overwhelmed with the picture.
  4. Br41ns
    Br41ns
    Apr 5, 2005
    424
    Glasgow
    +31
    :hiya:
    Heres my settings: for sky and dvd
    Mode standard: contarst 55, brightness 60, sharpness 60, colour 42
    or cinema: contrast 80, brightness 55, sharpness 60, colour 42
    For xbox: Standard, contrast 80, brightness 55, sharpness 55, colour 50
    In all the above i have DNIe on, DNR off Film mode off.
    My colours are blue 42, green 32, pink 42.
    Hope thats of some use. :smashin:
  5. jdslater1
    jdslater1
    Sep 4, 2005
    889
    28
    chadwell heath
    +39
    Done the settings that br14n recommended, can anyone with the 945 or 950 tell me what settings to put the player on. I'm running it through component as I didn't like HDMI.
  6. tiburs
    tiburs
    I'm wondering if the personal colour settings are usefull or not. Apart from the personal colour (not used), my settings are very close but with colour at 53. Don't you think you'd achieve same results just increasing global colour?
    Anyway I'll try yours this evening..
