Component on a budget
Discussion in 'Cables & Switches' started by Craig, Feb 25, 2005.
  1. Craig
    Craig
    Apr 2, 2004
    305
    Copenhagen
    +4
    I need a component cable of between 8 to 10 metres, dependent upon the WAF factor. So that's 10, then
    I have a budget of 50 quid, which I know is not going to buy me a nice Belden or Ixos, but can anyone reccomend something other than a Profigold that would suit my needs?
    Any help is, as always, much appreciated
  2. kismet110
    kismet110
    Feb 6, 2005
    2,364
    London, UK
    +389
    Check out www.cableuniverse.co.uk - they are friendly and efficient and sell a quality 10M component lead for around £41 + postage iirc.
    ALI
  3. Simon James
    Simon James
    Thanks! I need one like this too. :)
  4. Filbert
    Filbert
    Apr 6, 2004
    962
    46
    Pinner
    +195
    Just remember that over that kind of length, going for a cheap cable may not necessarily be the wisest move. Component video cables carry high quality video (compared to compsoite, s-video etc.) and over 10m can be subject to interference and signal degredation. You don't have to spend mega-bucks, just don't scrimp too much and not get the best from your equipment.
  5. Simon James
    Simon James
    Thats good advice. I don't mind spending £100...but can't seem to find any at a 10m length Only the cable universe one for about 45 quid.
  6. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    Is £140 too much? It's just Mark Grant's ones on the powerbuy section gets good reviews. So much I have one on order now! :)
  7. Filbert
    Filbert
    Apr 6, 2004
    962
    46
    Pinner
    +195
    Value, like beauty, is in the eye of the beholder, so only you can say whether £140 is money well spent or not! ;)
  8. paulflowe
    paulflowe
    Belden's 1505F cable. This is a slightly more flexible version of the 7710A, but has two tinned copper braids instead of a braid and foil combination, and a PVC jacket. It's possibly a bit cheaper too.
    Or...
    Three runs of 1695A cable. These obviously need to be exactly the same length. Cover the lot in high WAF braid and away you go - one very flexible cable. I use 1695A for my digital audio cable, and it's superb.
    Terminate with Canares or some spare RCAs I've got (as in the thumbnail) which we can discuss 'offline' :rolleyes:
    [​IMG]
    Just my 2p,
    Paul. :hiya:
