Component leads for dummies
simonx
So component leads are the read/yellow/white cables - there endeth my knowledge of the subject.
Could someone please explain in what all the brouhaha is about?
Keep it simple for me please! :rolleyes:
snow-munki
composite is red white yellow
component is green blue red ( yellow and white for sound )
basically component gives a better picture quality but you will need a compatible TV set, pretty much all LCD's will have them
Member 55145
red and white for sound :p
simonx
See what I mean! :oops:
I have a Sony Bravia LCD telly by the way, so what leads should I be looking to get?
Member 55145
if your tv has component input then get the official component cables
you can see if it has component input by looking for video plug holes (or phono inputs) of the green and blue type. if you can see them then your tv supports component.
a component cable has 5 cables attached
Red, Green and Blue for video
then two more which are red and white for audio
unfortunately there are two reds that look exactly the same, this is unavoidable but if you chase them down the cable it should be paired next to the white one for audio, and next to green and blue for the video
simonx
Thanks guys :smashin: - and would I be right to assume that the Nintendo component leads are rathe rhard to get hold of?
cochese
is there an actual known release date for the official nintendo component leads and who will be stocking them?
SeaneyC
Has anyone actually compared different component leads yet? I'm intrigued to know if the Ninty ones are actually any good, because to be honest they look a bit pants....
snow-munki
yeah well you know what i meant :p
oh do you guys find the green and blue leads VERY similar when reaching behind the Tv in the dark.. grr... whenever i have to plug them in, have to get a torch out.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
