Component lead helped needed urgently
Discussion in 'Cable TV & Virgin Media TV' started by DM1972, Aug 4, 2002.
  1. DM1972
    DM1972
    I've just taken delivery of a Toshiba 42wt29B RPTV and have paired it up with my trusty Toshiba SD200E DVD player by way of component leads. The problem is that I'm not getting any picture at all. Can anyone explain as to how I get it to work. I have the sound all sorted by using an optical cable, but I'm not getting any picture :(
    P.S. Does anyone know how to get into the serice menu so that I can adjust the 64 point convergence please?
    Cheers,
    Stephen
  2. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    In the DVD players menus - Make sure RGB is not selected instead choose either S-video or composite. I had the same problem at first with my Tosh 510. Its because the player cannot output RGB via Scart + Comopnent at the same time.
    Paul
  3. DM1972
    DM1972
    Thanks for the help Paul.
    You were right in stating that the output being set to RGB wouldn't work.
    I now have it set to VIDEO and it works a treat.
    Thanks again
    Stephen
  4. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Any Time Buddy
    Paul
