Component Lead help please
Discussion in 'Cables & Switches' started by AzleaAnn, Aug 22, 2005.
  1. AzleaAnn
    AzleaAnn
    hmm... I thought this would be easy ..but ... !
    I was using my Dvd player hooked up with a Scart cable which worked fine but my dvd player and Lcd Tv have Component connections....so I bought a set of Component leads from Maplin and pluged them in...I get no picture :mad: I can only get a picture if I plug the Scart cable back in !...and yes I have selected the Component option on my Tv but all I get is a blank screen ...any suggestions for a complete novice on what to do..oh I pluged in a couple of phonos to for the sound.
    Thankyou !
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Some dvd players need to be switched to componenet to get a picture. Other players Like my 757AI from pioneer, need to be switched to composite or svideo in order for the componenet signal to work. If the player is in RGB mode, the signal through the scart seems to overide the other ones.
    Take your DVD player of RGB mode and switch it to svideo or composite and see if you get a result :)
  3. AzleaAnn
    AzleaAnn
    Thanks Dave, there was a a setting within the Dvd menu that I had to set and now all is working perfectly....actually I have to say the picture quality using component connection is excellent...a much sharper picture to the RGB Scart to my eyes :thumbsup:
    Az
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Glad to help my friend :)
