Component interconnects : Query
Discussion in 'Cables & Switches' started by Snowboard, May 18, 2005.
  1. Snowboard
    Snowboard
    May 15, 2005
    16
    Worcester, UK
    I'm changing the connections in my system from composite to component. I have a 75 ohm digital coax (QED QNECT) left over from a previous use.....could I buy two more similar (digi-coax) cables to add to this and give me the 3 phono-phone connections that I need for composite ? - or is thee something more to pre-made 3-phone component cables that I'm not aware of ??
    Sorry if this is a bit dumb....
    Thanks...
  2. jamie110
    jamie110
    Apr 8, 2005
    380
    Walton on thames
    +16
    Good afternoon,
    I have no idea why this would not work? As far as I know it will be fine (there are more qualified people on here to answer this, and no doubt will!)
    If you do decide to go down this road, I have one of the same cables you mention, QNECT 2 @ 1metre which you can have for a tenner inc P&P
    Let me know
    Jamie
  3. severnsource
    severnsource
    Jan 19, 2003
    322
    +9
    There is nothing more to it than you are aware of. It's a good idea to use similar types and lengths of cable but you just need 3 75 ohm screened cables.
