component inputs
Discussion in 'Projectors, Screens & Video Processors' started by johnson, Jun 10, 2001.
  1. johnson
    johnson
    May 12, 2001
    550
    Essex
    +6
    I appologise for what might seem a daft question.
    If a tv has component inputs does that mean it is progressive scan capable?
    Thanks Simon
  2. Oasis
    Oasis
    Oct 7, 2000
    28
    3
    Sadly, No !
    Unless an input is specifically labelled as 'HD ready' or mentions progressive scan it will only be able to take interlace sources.
    It is impossible for Composite or S-Video connections to ever carry progressive scan, while RGB and Component can, but not always!
    Hope this helps,
    Oasis
  3. johnson
    johnson
    May 12, 2001
    550
    Essex
    +6
    Thanks Oasis,I appreciate the reply.
    Do you know if any of the current crop of crt rear pro sets will take progreesive?
  4. jon smith
    jon smith
    Jun 5, 2001
    3,320
    Leeds
    +137
    I know the Samsung 43 inch is progressive, but i think that is an LCD model. Still looks good, might get mine this week.
    Daft question, i've ordered a Pioneer 737 - how will I connect it to the Samsung - i.e. what cable do I need to connect them (any links of what/where to purchase appreciated here).
    Will this cable work for Pal and NTSC (even though the progressive is only NTSC?).
    Please help
    cheers, jon.
