Component Input Lead
Discussion in 'General TV Discussions Forum' started by logiclee, Nov 10, 2001.
  1. logiclee
    logiclee
    Aug 9, 2000
    1,591
    116
    Notts, UK.
    +673
    Can anyone recomend a decent component lead to go between my DVD player and Toshiba 46WH08B?
    Am I right in thinking its just a standard 3 phono to 3 phone lead connection?
    Thanks in advance
    Lee
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    RCA to RCA, just make sure it is 75 Ohm coax and that is all you need, less than £10 for all three should do it! (Maplin has what you need).
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    My toshiba 210 came with a cheap looking 3 way connector that works fine as a component lead. Didn't yours come with something similar?(I don't think it was intended to be used as a component connection but it does the job)
  4. logiclee
    logiclee
    Aug 9, 2000
    1,591
    116
    Notts, UK.
    +673
    Thanks for the reply's
    Ken,
    My DVD player is a region 1 import so I didn't get any leads.
    Done an internet search and Monster do a component lead but can't find any UK stockists.
    In HCC magazine they have recommended using component connection when possible but none of the main stream cable manufactures (Qed, Ixos, etc) seam to have these.
    Lee
  5. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    Ixos have the 171AV RCA to RCA RGB. You can buy this on line from www.hifistore.co.uk.
    You could also try www.htcustomcables.com Here you create your own cables delivery in 3/4 days
    10/10 for service from both.................;)
  6. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    I followed Nic's advice and got them from Maplins for less than a tenner.
    Excellent results:D :D :D
