Component input card to HTPC
Discussion in 'Desktop & Laptop Computers Forum' started by Nic Rhodes, Jul 24, 2001.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Jeff and Kryton seem to have found a high quality card to get signals into a PC (AVS), DScaler can then do it's bit (version 3 just out by the way). This card has S-Video.
    Does anyone know of a high quality card that can do component input as well as S-Video? Does such a card exist.
    [ 24-07-2001: Message edited by: Nic Rhodes ]
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Bump bump bump.
    I guess that no one knows of one then? Jeffs S-Video card then?
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Nic,
    I did a LOT of reserch trying to find the ultimate video in card. The main problem is finding something that is compatible with DScaler. From what I can make of it component or RGB support is not possible with the bt8x8 chipset. It can also only support 1 s-video in, although in theory if DScaler supported it you could have more than 1 capture card.
    The Falcon card which I bought works very well with Sky Digital, it also works well with my Sony DVD player but for some reason I notice some noise as apposed to virtual none with Sky. In any case compared to my other cards (WinTV and ATI TV Wonder) this card is miles ahead.
    Kryton is comming with me to the event so if you are going you should get the chance to see the card in action. I can't wait to see it compared to the rock. :D
    Jeff
  4. Jenz
    Jenz
    Jeff, who is bringing The Rock?
    Regards Neil.
  5. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I have no idea ;)
    Blade?
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Jeff
    Kryton is one of the main attractions for me at the event, though I must admit I have several other / related interests (scalers). Don't be surprized if I pick your brains a little, if you don't mind. I can show you my effort. I'm proud of it but I need to work on a few things like software config, quieter DVD drive and S-Video in, first. The rest works well though not in Kryton league.
    My next stage was to check out the bt8x8 chipset to asses it's capability. I currently have a Radeon AIW but the S-Video is nothing special. This can easily be swapped for my Geoforce Ultra and one of your Falcon cards which may be a better solution. I would need a separate TV PVR then though.
    One S-video input is not an issue as the AV32R does the switching in my case.
    I am very interested in the Vigetec agianst the Rock against Kryton. This will allow me personal experience rather than reading at AVS. :)
  7. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    John,
    That sounds great!, I'm struggling with the dscaler settings. I have changed a few like turning on the gamma filer, but with many of the settings I can't tell what effect it's having on the picture. I have read the settings info on the DScaler web site but I could do with something that explains the effects with a little more detail. Any tips in advance of the event? :)
    Thanks,
    Jeff
  8. JohnAd
    JohnAd
    Mar 14, 2001
    362
    London
    +4
    It's difficult to know what you need to know about until I've seen your setup. We spend quite a lot of time making sure the defaults for most things are correct.
    Most of the setting that would effect the picture are the picture controls and the overlay picture controls. I'm not really clear how these interact yet and which ones to set first.
    I was thinking that most of the changes we would go over would be automation/control and optimizing the picture for PAL and NTSC for both DScaler and DVD.
    John
  9. JohnAd
    JohnAd
    Mar 14, 2001
    362
    London
    +4
    Nic & Jeff
    Maybe we should arrange a HTPC breakout session where we could try and fiddle with Kryton to make it even better. There are load of Dscaler settings we could play with for example and I'm sure we can play around with powerstrip to try and get really good timing for both NTSC and PAL DVD's.
    John
  10. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I'm Game.
  11. Gordon @ Convergent AV
    Jul 13, 2000
    14,210
    +3,048
    Guys,
    I seem to be slipping up here. I will now email those folk who oofered equipment for the event and confimr whether it will be available.....I'm sure it will.
    There will be a room dedicated to scaling technology demonstrations and comparisons. The shop is too small and the event now too large to dedicate comparisons of just a rock / vigatec / kryton or for Kryton to be tucked away. I would expect though that as not everyone is interested in Dscaler, or even LCD/DLP projectors, you will have plenty of chance to muck around and chat over the space of the day. Let's see how tings pan out. If HTPC proves a huge hit we can always get more tweaky as the day goes on.
    Remember, the only really structured part will be the morning session. The rest will be fly by wire stuff. To make it sensible though I'll put John in the scaling room along with someone who can work the Seleco800 CRT we'll be using. How does that sound?
    Gordon
  12. Craig Crane
    Craig Crane
    What you really need is a KBK modified TV card. There improvement is amazing. No need for a TAW rock, when used with Dscaler. As for my old and trusty DVDo iscan. Pah! I'll have to see what I can get for it in Loot!
    More details over at AVS (http://www.avsforum.com/ubb/Forum12/HTML/013038.html#4) and on my Home page.
    Trust me, this KBK guy from canada has pulled apart the best TV card, looked at its strong points, addressed its weaker points and delivered a Capture card that is great for LD, Sky and Play station. No need to scale DVD, as I use S/W players.
  13. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Craig how about some Sky Digital snaps so that I can compare against the falcon. Some have accused the KBK's picture to be a bit on the soft side. Also if you press the sky service button followed by the backup button do you see any noise on the blue screen?
    Jeff
  14. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    East Yorkshire, England
    +171
    Hello Craig,
    Would it be possible for you to post a close up picture of the modified card?
    I would really like to see one of these close up.
    I have been going to get my soldering iron out to modify some Cybertainment cards for a while, but have not got round to it yet, just need a little motivation.
    Anyone got a really close picture of one of the Falcon cards?
    Thanks,
    Mark G.
  15. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    My Falcon come tomorrow. Thanks for the input Jeff.
  16. Tim Cooper
    Tim Cooper
    Sep 20, 2000
    2,858
    71
    Laindon Essex
    +96
    Hi Jeff,
    Where can i purchase one of these falcon cards & how much are they?
    Just to let you know that "Kretin" is performing brilliantly, beautiful on my new Barco <img src="biggrin.gif" border="0"> <br /> <br />Having real grief automating (methinks i need a pronto)& that Girder proggy what a GIT to do ANYTHING........is it me?
    Tim
  17. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Here is the Falcon link.<br /><a href="http://www.iste.com/video-capture/falcon.html" target="_blank">http://www.iste.com/video-capture/falcon.html</a>
    It costs £145 + vat
    Girder is a pain to use, I still don't have many commands. I mostly use it to start and end programs. Hopefully with the DVD and DScaler (mostly) sorted I can do some more atutomation work.
    Jeff
  18. Craig Crane
    Craig Crane
    Gentlemen, I can post Sky Digital pics, but no close up of the card. This is because I feel that KBK offers a good service/product, and I would hate to see him being reversed engineered. Plus, I paid good money for the card. If you want to see one close up, take the plunge...you'll be glad you did
  19. Craig Crane
    Craig Crane
    ...there is no noise on the Blue Sky services screen you mentioned. I viewed it on a 8 foot screen. Clear as a bell
  20. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,368
    63
    +171
    Here is a link to an RGB capture card.
    <a href="http://www.datx.com/products/hardware/dt3154.htm" target="_blank">http://www.datx.com/products/hardware/dt3154.htm</a>
    Doubt it will work with Dscaler, but the picture on the site shows it has a BT chip, so I can hope......
    It has two RGB inputs, so we could capture RGB from a standalone DVD player and a Satellite receiver.
    <br />Mark G.<br />(also posted to the 'other' forum)
