component help
Discussion in 'Cables & Switches' started by sunderland, Sep 10, 2004.
  1. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    i was just wondering when you connect using the component cables do you have to use the separate audio cables to get the sound to the tv thanks as ive never used this before so that means 3 comp cables and 2 audio cables :lease:
  2. BrianC
    BrianC
    Jan 20, 2003
    2,199
    +101
    yes, you will normally need the audio leads on top, sometimes they are included with the (cheaper) component lead sets.
  3. sunderland
    sunderland
    Oct 29, 2003
    4,527
    2
    83
    northeast england
    +242
    thanks for the help just as long as i no now cheers.p.s will it still auto turn over to component channel like it would do with scart av thanks :thumbsup:
