Component / HDMI cable??
Discussion in 'Xbox Forums' started by Bailey83, Feb 12, 2009.
  1. Bailey83
    Bailey83
    Dec 28, 2008
    14
    Hello,
    Just bought myself a new Xbox 360. Its comes with the standard Component cable (5 coloured plugs), does it make any difference and is it worth the expense to use a HDMI cable instead?
  2. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    Yes and no. Your TV may not accept 1080p over a Component connection in which case you will probably be better off with HDMI. Otherwise, as long as your happy with the picture quality of component then stick with it.
    On the other hand though, I use a £3 eBay HDMI cable without problem and I am very happy with it.
  3. Bailey83
    Bailey83
    Dec 28, 2008
    14
    Oh yeah, I get decent 1080p over the component, just wondered if using the HDMI provided any further improvement in picture quality.
  4. thelegendofyrag
    thelegendofyrag
    May 4, 2007
    1,436
    48
    Nr. Bury St Edmunds
    +74
    i've heard you dont get much difference. I use component on a 1080p and it looks great. It hasn't been compared though. So i can only say what i've heard from the majority.
  5. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    It's subjective to a certain degree and to an extent it also depends how your display handles the various inputs. IMO whilst close I would say HDMI is slightly better then component but then I only have a 26" 720p TV at the moment.
    Bare in mind that if you use HDMI and are using the digital optical for sound then you will need to get the optional AV adapter/dongle in order to connect both at the same time. Either that or modify the AV cable by taking the outer casing off.
  6. Geordiepete
    Geordiepete
    Aug 17, 2006
    404
    28
    +32
    I prefer the picture over component on my setup.
  7. Bailey83
    Bailey83
    Dec 28, 2008
    14
    Well alright cheers everyone, guess I'll be sticking with the component then. Hopefully be upgrading to surround sound sometime in the near future so as mentioned I'll need the digital sound output.
  8. MetalMonkee
    MetalMonkee
    Feb 10, 2009
    81
    +5
    What about the VGA cable? Surely the resolutions generated with that cable with be superior than 1080p?
    Ive just checked my xbox 360 settings with my VGA cable and its running in 1280x768 yet my TV supports 1080p which is the equivelent of 1920x1080 (which i have an option of selecting but when i do the screen turns blue).
    Im thinking that if i was to get a HDMI cable i could run it in 1080p right? That would confuse me if thats the case. My TV will support HDMI 1080 but not VGA 1920x1080.
    Im using a Samsung LE32R32.
  9. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    OP: hdmi cables are only a couple of quid, why not try one and see which picture you prefer?
    One thing thats been mulling around in my head about resolutions. I believe most games are designed to run at 720p, so all you achieve by running at 1080p is that the 360 upscales the picture rather than the TV. If this is the case and considering the failure rate and noise generated by a 360 that is attributable to heat doesn't it make sense to leave the upscaling to the TV and reduce the workload on the 360.
  10. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    Real guitars don't have strings, they have 5 colou
    +934
    Also there is a difference between accepting 1080p and displaying 1080p. There are several sets that only display 720p but can accept 1080p, in which case using 720p will definately provide the best picture.
  11. MadagascAL
    MadagascAL
    Dec 27, 2008
    247
    Chester
    +37
    I've noticed little difference between component and HDMI on my 32" Samsung LCD (720p).
    I use HDMI from my Xbox so I can hook up the Wii using the 1 x component connection on my TV.
  12. ajwatson
    ajwatson
    Nov 11, 2008
    161
    +17
    I'm with this guy i do the same thing wii on the component and xbox 360 on the hdmi then i get the best of booth worlds plus, imo it looks far better through the HDMI and the sound is far clearer on my 46" samsung (1080i)
  13. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    I think only HDMI and VGA provide upscaling for DVD's on the console as well, if that's of interest to you.
  14. MetalMonkee
    MetalMonkee
    Feb 10, 2009
    81
    +5
    They do. :)
  15. rb5201
    rb5201
    Apr 20, 2005
    2,142
    63
    essex
    +220
    Is there anyway I can get HDMI cable connected to my original 360 or is it only the elites which will accept this?
    Currently got it connected to my amp via component, but got 3 spare hdmi slots but no more component, could do with freeing up that for my wii.
  16. DragonOfSilver
    DragonOfSilver
    Dec 23, 2005
    1,085
    48
    +73
    Only with a convertor of some sort, I believe madcatz did make one that goes straight into the 360, but I don't know how well thse would work. you could look at a vga cable instead if your tv has a vga input?
  17. evangelink
    evangelink
    Jan 11, 2009
    404
    London
    +36
    I haven't noticed a great deal of difference between HDMI and component, and only use component as my 2 HDMI slots are already taken up.Weirldy though, my component connection seems to take a while to 'warm up', as initially for 2 minutes or so I get these fuzzy little lines on everything, like at the edges of any colour banding. It's strange but does go away quickly so I'm not too worried, be interesting to know if anyone else has had that trouble though.
  18. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    +934
    I think your ALONE in that.
  19. evangelink
    evangelink
    Jan 11, 2009
    404
    London
    +36
    Damn, must just be me then!
  20. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    Any current 360 will offer HDMI, from arcade through to elite, its the age of the console that determines if it has a hdmi port not the spec.
  21. rb5201
    rb5201
    Apr 20, 2005
    2,142
    63
    essex
    +220
    Its my 3rd one Ive had now, all sent back from microsoft, not sure if its the same machine or a refurb!? Cant see a HDMI port on the back though.
  22. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    I'm pretty sure microsoft either return your own machine or a matching one. So if your original doesnt have hdmi neither will any they return to you.
    On a machine with hdmi its directly beneath the existing video port.
  23. MadManMax
    MadManMax
    Feb 17, 2009
    Does this mean that the upscaling on DVD's only works through HDMI or VGA...?
    Sorry a bit of a n00b at this...
  24. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    Yep, apparently upscaling a DVD over component is against the DVD spec/rules. :suicide:
  25. cas398
    cas398
    Nov 25, 2007
    2,530
    Glasgow
    +184
    Both.
    Not component.
    Component I think uses 'progressive scan' which is supposed to make the picture look a bit better, it's not as good though. Don't quote me on that :rolleyes:
