Component HD + Stereo Sound Distribution
Discussion in 'General TV Discussions Forum' started by Litch, Apr 25, 2005.
  1. Litch
    Litch
    Dec 20, 2004
    84
    +10
    Hi Guys,
    I have been looking at a way to distribute HD component video (480i, 576p/i, 720p & 1080i) with stereo sound from by living room equipment to the bedroom and kitchen.
    Has anyone heard of / used / had any experience with the following products:
    Click here
    As this looks like the perfect solution. :)
    Any feedback would be very much appreciated
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    have a look at www.extron.com and Gefen and speak to Joe F at the media factory he deals with Gefen and Zektor kit which will do what you need.........
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,909
    The Borders
    +3,126
    Hello both
    Litch - I've not used or worked with the kit you link too; though as Horny says there are alternatives.
    What distances are you envisaging for the cable runs?
    Is One to Many you ideal solution or would you prefer to have the ability to distribute Individual signals to each Display?
    Will you want 'remote control' of your source/sources in the 'remote' locations and if yes do you have a solution in place?
    YUV to CAT5 solutions are not all created equal - some are quite transparent others add unwanted artefacts to the image at the remote end.
    Best regards
    Joe
