Component has no audio right?( Newbie Alert)
Discussion in 'Cables & Switches' started by Hotshot147, Jun 23, 2005.
  1. Hotshot147
    Hotshot147
    Feb 22, 2005
    96
    +4
    I will be getting a plasma shortly, and i dont have any surround yet.My question might sound silly to the experts ,but if i hook up my dvd with component leads will i be able to get sound somehow.Do i need some extra leads from my dvd to plasma.
    Regards.
    Chris... :)
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Well it depends on what plasma you are getting and what DVD player you have.
    The panasonic plasmas and Crt tvs share the AV4 input with scart and componenet. You simply hook up with a scart lead and componenet leads, watch through the compoenent input and get sound throught the scart lead.
  3. Hotshot147
    Hotshot147
    Feb 22, 2005
    96
    +4
    Thankyou i'm getting a pv500 so i should be ok then.
    Cheers.
    Chris...
  4. Zone
    Zone
    Jun 24, 2001
    6,736
    Barnsley
    +2,424
    To be specific to your original question then Component is purely visual only!
    Sound has to be treated seperately, I have no experience re your particular plasma so take Daves advice re the Panny.
  5. Hotshot147
    Hotshot147
    Feb 22, 2005
    96
    +4
    Thanks for your input Zone. :smashin:
    Thank you.
    Chris...
  6. Moncs
    Moncs
    Jan 14, 2002
    467
    Edinburgh, Scotland
    I to am getting a PV500 next week, and planned to connect my Denon DHT500 to it via a good quality component lead, can anyone recommend one??
    I thought that component carried sound, what is peoples opinons on what else I need to connect the denon to the PV500 over and above the component lead?
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    One of the best value/quality component leads you can get are These from the forum powerbuy :thumbsup:
    They are highly recommended by many members of this forum.
    Mark.
  8. SonOfSony
    SonOfSony
    If you have surround sound DVD then you won't need to worry about connecting a SCART for sound. Just the component will do.
