Component / DVI / Coax - interference expected?
Discussion in 'Cables & Switches' started by fbs, Jan 20, 2004.
  1. fbs
    fbs
    Dec 13, 2002
    15
    3
    In holding pattern near Glasgow
    I've just ran 10m of component cables from my projector to my DVD player up through the ceiling and down a nice channel I've cut into the plasterboard wall. The cables are housed in some trunking from B&Q.
    My question is how much interference will I cause to my component feed if I run a VGA/DVI cable alongside... and some coax to a Sky box? If it's dependant on the quality of cables can someone advise of the specs required so as to cause as little interference/conflict/whatever as possible?
    I've saw a few installs on the forums where it looks as though folks are running the full quota of cables to their projectors.
    Ta.
