Component dvd help
Discussion in 'Plasma TVs Forum' started by Macleanrd, Jan 19, 2005.
  1. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Hi All
    I bought my pw6very cheaply last month,I have my sky connected via a scart sync vga cable and the picture is good.
    My dvd surround system is a pany SA-MT1 which also has good picture but I have to disconnect the sky scart from sky and plug it into home theartre to watch dvd( i do not have component on this)
    I have about £300 to spend on a dvd home theartre system that must have the 3 component connections to replace the above mentioned.
    The questions are
    1...will component be much better than my current set up?
    2...Obviously i need a component board for the plasma, so where can i buy one?.....all the places ive contacted wont sell one unless i buy the plasma at the same time and obviusly i dont want to buy another plasma lol
    3...what dvd home theartre can i get for about £300 that has component?
    Many Thanks
    Steve
    Ps.....sky will still be watched through scart vga sync cable.
  2. dave0523
    dave0523
    Dec 28, 2004
    261
    Somerset
    Panasonic SCHT-870 £299
    Works fine for me.
  3. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    I just had a thought, is there one that comes without the speakers as i can use my old ones?
  4. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Any others.........preferably so i can use my old 5.1 surround speakers as they are only a year old.
    Also answers to questions 1 and 2 would be appreciated.
    Steve
  5. Parklife
    Parklife
    Jun 9, 2004
    566
    28
    +33
    You could always pick up a second hand amp and buy a new DVD player. This should give you better sound anyway than a home cinema system.
    Or by stretching the budget a bit get a new amp and dvd player.
  6. cyberbob69
    cyberbob69
    Dec 31, 2004
    400
    Midlands
    +19
    Answer to question 1. component is a lot better than standard scart. Is your player RGB out? If so a JS RGB to VGA converter would give you even a better picture. To be honest thou I don't know much about scart sync vga cables. :blush:
    Answer to Question 2. Give AV-Sales a ring. I think they might be able to supply the board, I'm sure someone on here said they do. Not 100% thou.. :thumbsup:
  7. Anthall
    Anthall
    Oct 27, 2004
    219
    Kettering
    +4
    Panasonic SCHT-870 here also connected to viera.
    Very happy with the above but confused on how i can
    get my video recorder to use the all in one system to produce sound?
    Any ideas anyone, or Major how have you got around this???
    Cheers big ears.
