Component connections for PS2/XBOX/GC/DC on Panny PW7
Discussion in 'Plasma TVs' started by Davidgilmour, Sep 14, 2005.
  1. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    765
    Amsterdam
    +13
    just installed my 2 componennt cables with the XBOX/PS2 and GC.
    XBOX = full screen
    PS2 = not full screen
    GC : not yet tested
    What are your experiences with the Component PS games on these 3 consoles?
    And does anyone remember the Sega Dreamcast ?
    Well, it can do some 480p games too!
    http://www.hdtvarcade.com/othersystemslist.htm
    Anyone got experience with 480p games on the Dreamcast?
    You need the VGA box for the DC with the VGA-Component convertor.
    rather expensive.
  2. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,799
    Caterham
    +59
    I should have my plasma soon, I can dust out the old DC for some Metropolis Street Racer goodness, when you say not full screen though how do you mean? Also, have you done the high def mod for the xbox?
  3. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    765
    Amsterdam
    +13
    xbox has no bars on the left / right side and none above / under
    the ps2 has bars on the left side and right side.
    the xbox is modded, don't know how though.
  4. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    Have you tried setting the PS2 to widescreen in the set-up menu?
  5. kenji-san
    kenji-san
    i havethe some problem with ps2, it's like there is a little black bar all around, as if the geometry isn't correctly adjusted. with your pw7 you should be able to correct this manually though.
  6. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    765
    Amsterdam
    +13
    Yeah, thats what it is. The XBOX has full screen but the PS2 doesn't have it.
    But if I set it manually the PW7 will save it into its memory, won't it?
    What will happen with the XBOX pic, will that go out of bound ?
  7. Mep
    Mep
    Dec 25, 2004
    9,497
    +460
    yes it will.....and with mine we get it the other way round! but we can live with it....it's still a million times better than the old 28" / 32" screens we used to have.
  8. Davidgilmour
    Davidgilmour
    Jan 31, 2004
    765
    Amsterdam
    +13
    I also connected the Gamecube, some games are Full Screen, some not. Very strange. icrosoft's first console gets it 100% right, funny.
    Is this a Panny thing or do other plasma's suffer the same thing?
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    No, it's not a panny thing, it's stupid Sony. Our PS2 is connected to it's own input on the scaler for this reason, it's zoomed on it's own that way. Strangely, if you play a DVD in it, it's full screen, it's just games that do this.
  10. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    Just bought a PS2 component lead and I see what you mean now. How annoying.
    Will we end up with this image retention of this border unless it's zoomed in when using the PS2?
  11. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Picture's surprisingly good though. I guess it's just a q. of resizing the picture if going for a long gamind session, or maybe (if you are a panasonic panel owner), lashing out on another component board. It remembers settings 'per input'
  12. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    I do have a panny and I was considering getting another component board. Which settings does it remember, the aspect settings?
    Is they any way of stretching the picture to fill the screen on a PWD8? Just checked the advanced menu but couldn't see anything useful.
  13. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Picture position/size!!! Yes it remembers. If you have a prog scan DVD as the only other component input, it can remeber settings for both independently on the 1 input, so no need for a new card. It's 576i, which would be the same as a set top box like netgem, or converted sky, so settings for PS2 will affect sky etc, but not prog scan DVD
  14. SteveG
    SteveG
    Jan 14, 2003
    1,024
    London, UK
    +87
    That confused me until I looked at the remote! How have I never seen that button?! My excuse is I've only had it a week..
    The component is currently used for a Pioneer DVD-656 which is progressive scan. Thats handy.
    The only complaint I have is that the phono connectors are joined to the component wires and have about 5" of slack on them. My amp is 3 feet below the TV, so I'll have to run phono extenders in the wall too. I've just found the first downside of not having TV speakers!
    Thanks for the info MAW!
