component connections - denon dvd 2910
Discussion in 'Blu-ray & DVD Players & Recorders' started by neilos70, Jan 15, 2005.
  1. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    please help!
    ive just upgraded from a tosh sd220 dvd player to the 2910...One problem though - ive used the component outs to my tosh tv as before (which is not prog scan compatible i presume - plasma not bought yet) and cannot get a picture on dvd playback.
    i have played about with the settings and selected interlaced for video etc but still no joy.
    it only works with a scart connection (to my disappointment i have to say).
    can i still use the component outs without progressive scan being activated or am i just going to have to use scart for now??
    thanks for your knowledge & help in advance.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    Have you set the DVD to output via component in the setup menu?
    The DVD player may be by default set to output RGB over scart and in most cases this will mean the component outputs are not active. Connect via scart, set the output to component (or sometimes anything other than RGB) and all should work. You can then remove the scart lead.
    Mark.
  3. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    hi mark,
    thanks for that...i'll try this & get back to you when i get home from work today.
  4. neilos70
    neilos70
    May 28, 2003
    233
    hertfordshire
    +4
    :clap: mark, its now working - set to interlaced & rgb it now works a treat in component out.
    thanks very much!!!
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    Pleased to hear you got it working ;)
    Mark.
