Component connection on Panasonic Plasma
Discussion in 'Panasonic TVs Forum' started by sbrough, Sep 1, 2004.
  1. sbrough
    sbrough
    Hello there,
    Can anyone tell me if there is a setting on a Panasonic TH-37PE30B plasma TV that allows you to switch between RGB and component ?
    I cannot get a picture from my DVD through component but I can through scart.
    I have tried the differant options on the DVD and I still have the same problem. This only leaves the TV which may be the cause of the problem.
    Thanks in advance.
  2. Seanjackdan
    Seanjackdan
    Select the blue button on the remote, and each time you press it, you go from AV4, to AV4S, to AV4C. The last one is component - hope this helps !!!!!!!
