Component confusion?
Discussion in 'Plasma TVs Forum' started by dspud, Jul 22, 2004.
  1. dspud
    dspud
    Hello,
    I've read as much as I can about progressive scan component, etc, but I am still confused!
    I am looking at getting a plasma which has the following input specification:
    YPbPr: 480i, RGB-PC: 480i/p, 720p, 1080i
    I have a H/K DVD22 player which output NTSC/PAL progressive scan via its component outputs.
    Does the plasma specs above indicate that I won't be able to receive a progressive scan signal from the DVD player?
    What about a Component -> PC VGA cable? Would this work for progressive scan component? (it mentions 480i/p in the PC VGA specs).
    Thanks very much for taking the time to help me,
    -- spud
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,218
    +3,073
    From those specs it says it wont work.
    Component to the VGA will not work either.
    To do what you want you need a transcoder to change 480P YPrPb to RGBHV colourspace. Even doing that it looks like this plasma will not accept 576P (pal progressive) in any format
    Gordon
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Most unusual these days, what make is that?
  4. dspud
    dspud
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    852 (H) x 480 (V) pixels, a brightness of 1000 cd/m2
    PD42 Glass TV also offers full compatibility with all video signals and all available inputs, including:
    Video
    S-Video
    SCART
    Analog RGB [PC]
    Antenna [75 Ohms – VHF/UHF]
    Video/S-Video stereo input
    PC stereo input
    Line stereo output
    External speakers.
    Not anthing to write home about there!
    what is so stylish about it???? have you seen the pioneer? or Panasonics???
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=5588&taxonomy_id=62-63
    http://www.panasonic.co.uk/plasma-tv/th42pe30b/index.htm
    You dont need the stand!
