component cables
Discussion in 'Blu-ray & DVD Players & Recorders' started by john_bowler, Jun 26, 2002.
  1. john_bowler
    john_bowler
    I have recently bought a marantz dlp VP-12S1s projector and I am told that I should buy a dvd which uses component cables as the quality is far superior - mine is a panasonic dv626d. Is there anyone who can give me advice on what is good out there for about the same price. A shame as the panasonic is as new. :(
    It has scart, composite, and s-video connections but no component connections.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Firstly I would determine what inputs the projector has (S-Video, Component, RGB?)
    Secondly RGB will be equal to component (interlaced/non-progressive), so if your player has RGB output (via SCART) you may use that. Use an adapter cable if necessary.
    Thirdly, if you want to go progressive scan (non-interlaced) all the above won't matter and you will need to use component connection. If the projector doesn't support it then, well, it won't work. ;)
    (Check first if the DVD player supports it, too!)
  3. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'm not convinced I've connected my Sony 10HT upto my DVD player (Tosh SD9000) with both S-Video and component, and in all honesty I can tell naff all difference.
    If it was a case of buying a cable to test maybe worth it, but if it means changing a DVD player that otherwise your happy with, them I'm not so sure.
  4. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    Was the cable decent quality when you A/B tested Svideo and Component?
    I only use a run from my Pioneer 737 to Scaler of 1 mtre and can tell the difference easily over svideo . Much better colours and fine detail.
    As for choice of DVD player, you will be best to try and demo at home, but the Tosh does seem as steal at the mo.
    Rgds
    Nathan
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Yep they're both fairly decent cables at the moment, Lektropacs proffesional range, I also borrowed a short run to test with the pj (was an expensive monster cable) and still couldn't notice any difference, maybe I'm just blind or the Sony has an excellent s-video input, or the Tosh component output isn't that good.
  6. Guest
    I've got to agree with slingshot over whether there are any benefits with component over svhs. I've got both component and svhs coming from my tosh with the svhs running through my processor and i can't tell the slighteset difference either.
    Jason
  7. chris thomas
    chris thomas
    I"d recommed vision xpress boys, get yaself a decent set. :D :p ;)
  8. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Slingshot
    You are quite correct but our 9000 are the exception rather than the rule. Toshiba 9 series players (and others actually) have a quality of engineering in the SVideo interface that is only bettered by Tag IMHO. Poor old RGB Scart owners.:D
    If only all players were made like this, people would be happier with their players and the whole world could standardise on SVideo.
