Component Cables
Discussion in 'Blu-ray & DVD Players & Recorders' started by tolmie, Sep 24, 2005.
  1. tolmie
    tolmie
    Dec 10, 2004
    982
    Glasgow
    +55
    Hopefully this is in the right forum, im thing of getting QED component cables for my pioneer 575 DVD player, would I notice a big difference over my Thor Scart cables.
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    Component is generally acknowledged as a better connection option than SCART, and it would also bring with it progressive scan which I think the SCART signal doesn't provide.
    Note that component, unlike SCART, carries video only hence you'll need to make other arrangements for audio, usually a separate surround sound system...PJ
  3. tolmie
    tolmie
    Dec 10, 2004
    982
    Glasgow
    +55
    Ye i no about the audio, i only want to know if it will make a big difference from scart.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    A lot depends on your display. Some will give a poor picture with even the best YUV component cables, but perhaps a good RGBcvS picture via scart. But in most cases YUV will beat scart, especially if the DVD player can output a progressive signal (and the display can accept it) that can only be sent via YUV. Also the bigger the screen the more you are likely to notice a difference.
    Mark.
  5. Mark F
    Mark F
    May 2, 2005
    387
    28
    +37
    A good dealer should be willing to lend you a component cable so you can see for yourself.
  6. Mep
    Mep
    Dec 25, 2004
    9,551
    +472
    you probably mean thank you
  7. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    :clap:
  8. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    I would get the Mark Grant cable, as its a s good as it gets and dosnt cost the earth :)
