Component Cables??
Discussion in 'Plasma TVs Forum' started by Fozz, Mar 23, 2005.
  1. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Hi.
    I have just attempted to connect a DVD player to the PW7 mediabox using new Component cables.
    Now, these came with screw tops on near the tops that had the red/blue/green colour coding.
    I attempted to connect the first of these but it simply would not go onto the corresponding connector on either the DVD or the Mediabox.
    So i screwed the top part off revealing the gold connector part underneath.
    This slid onto the connector fine.
    I did the same with the other 5 connectors, noting the colour of the top each time and I believe I got em in the correct sockets (without the screw off covers I cannot tell which is which).
    I then noted that I could screw back on the cover and just not tighten it and the cables slid over the component connectors fine also.
    However, when I turned the Mediabox and dvd back on I can hear the sound of the DVD fine but the AV4c channel on the Mediabox picks up no signal.
    Hmm...so I then reversed the two end cables (Green and Red) on one end to see if I may have got em wrong.
    Still nothing.
    Note that the DVD player works fine using SCART.
    What are my options here?
    I'm confused and a bit frustrated at the thing now.
  2. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    this might sound stupid but what about trying this;-put all the screw tops back on,selotape small peices of paper with the corresponding colour wrote :thumbsup: onto each one then take the screw ends off then reconnect.
  3. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Em, but the screw tops will go on any of the connectors...they all look identical.
    I have since put the screw tops back on and the only thing that I am (kinda!) sure of is that the centre cable of each end is the Blue one.
  4. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    also is your player set to component and not scart.
  5. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    my dvd player has to be set to component or scart
  6. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Ok, yea..I am wondering about that now.
    Note that I was able to see the correct cable colour and screw the correct colour coded tops back on so I know the cable is back as it was.
    Now, where do I set the DVD to Component?!
    It's the DVD player that comes with the Yamaya S200.
    I'll go back and look in the manual some more but I havent found that yet...
  7. Fozz
    Fozz
    Nov 15, 2004
    76
    Dublin, Ireland
    +4
    Cheers Pioneerman.
    Sorted so I am!
  8. pioneerman
    pioneerman
    Mar 25, 2004
    2,530
    71
    surrey
    +63
    good glad to be of help
