Component cables for GC/X-Box
Discussion in 'General Video Gaming Chat' started by GPMCDERM, Jan 1, 2003.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    has anybody tried using component cables with either
    their Gamecube or X-Box.....I've tried the PS2 using componet
    a projector and 7ft screen, now I know the bigger you blow
    it up the worse the picture gets but the picture from the PS2 is
    crap to be honest really shows you were the corners were cut
    on the video side of PS2 but the S-video picture is very good....
    Just want to know is the GC/Xbox are any better before spending the cash on the leads...
    CHeers....
    Ger
  2. CarlB
    CarlB
    Jan 8, 2001
    1,101
    Godmanchester, Cambs
    +86
    I use component and progressive output with both my XBox and GC to a 42" Panasonic plasma. Both consoles look superb at that size, though I don't know about a 7' image.
  3. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Thanks for the reply.....tell me are your GC/Xbox US systems
  4. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Gamecube Component is superior to the standard RGB from a PAL machine. Likewise, it is superior to S-Video on a US machine. RGB on a US machine is just as good as Component since the same high-quality cable (with modification for RGB) is used. Import a Gamecube Component Cable from:
    http://www.ncsx.com
    or
    http://www.tronixweb.com
  5. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,477
    Chesterfield town of the crooked (Spire)
    +72
    Although i can only get interlaced component as my tv doesn't do Prog Scan:( my import GC and pal xbox display a superb image via component.
  6. CarlB
    CarlB
    Jan 8, 2001
    1,101
    +86
    Yes, my XBox and GC are US machines.
  7. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,187
    41
    London
    +6
    Early PAL xboxes support HDTV and progressive modes also but this was a bug that MS have fixed in newer boxes and when you upgrade to Live.
    But your best bet is to use an import console. PS-2 also has component in and most new games support Progressive.
    Cheers,
    Neil.
  8. paulMK
    paulMK
    Jan 2, 2003
    46
    East Anglia
    Sorry to tag onto this thread...
    Does anyone have a Sony TV KV28LS60TNS or KV32LS60TNS and a US GameCube using the s-vhs connection - does it work, and do you get colour?
    Is there any other way to connect a US Cube?
    My current TV and the TV I am thinking of buying do not have Component.
    Many Thanks
    Paul
    How much fooking longer for Zelda?
  9. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Assuming the two Sony's are recent enough televisions, they will support NTSC 3.58 MHz and you will get a full colour picture via S-Video. Most televisions, Sony especially, will support this. I have a 21" Sony Wega bedroom set that supports NTSC 3.58 MHz via S-Video so I would assume the more expensive sets in the range will also.
    Zelda (US) is coming out March 24th. Get your pre-order in early to ensure a copy of the Zelda bonus disc with Ocarina of Time and Ura Zelda games on it. This should ship in Feb.
