Component cable???
Discussion in 'Projectors, Screens & Video Processors' started by yamman, May 8, 2003.
  1. yamman
    yamman
    HI folks,
    anyone recommend good supplier of 10 mt component and 10 mt s video cable.I am not looking for top end quality,just good honest middle of the road cables at the right price.
    cheers!
  2. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    10m Component Cable
    CPC do some cheaper ones too if that one is a bit rich ;)
    10m S-video
    The above is a Van Damme cable which is good enough for anyone that cares about the contents of their wallets :)
    -- Jon
  3. yamman
    yamman
    jon,thanks for info.
    Have you tried these cables yourself and if so what do you reckon?
  4. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    www.intoav.com
    Component lead is superb quality. These guys actually build camera run leads for the BBC so they are used to making long quality leads.
    I hope that this helps.
    CB.
  5. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    If you want Van-Damme cable's check out www.vdctrading.com they will make them up to any length.
    Also check out the Van-Damme, Hifi professional phono plug as your connection. very good value and ready by the next day.
    Samir :)
  6. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Samir,
    Was this the component cable you meant?
    Van Damme red series 75 ohm ofc video multicore
  7. gothmog
    gothmog
    Dec 17, 2002
    204
    16
    Sunny Shipley
    Yamman, yes I use both picture-wise no complaints.
    The Van Damme S-video gets a special mention for surviving me wrapping it round my drill bit when I drilled into the ceiling and it was running through the loft :clown:
    -- Jon
  8. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    I made mine up with 75 oh co-ax from Maplins (can't remember but thin it was about 50p per meter) and soldered on their own gold plated phonos. (£2 each)
    Seems fine but at some stage I'd like to compare them to a 'branded' product. Or am I suffering from "Its cheap it can't be good!!!"
    Incidentally I look in a Russ Andrews catalogue and their top of the range cable 10m length X3 for component would have been........£40,000.00!!:eek: :eek: :eek:
    Still saving............
  9. petrolhead
    petrolhead
    Mar 29, 2002
    4,776
    Newcastle
    +115
    How about a wanted ad in the classified section of this forum?
  10. SamirP
    SamirP
    Apr 28, 2003
    1,303
    South Of The River
    +38
    Hi PFM
    I meant the normal 75 ohm video cable not the multi-core, but both would do the job fine.
    It's just down to which you one like best ;)
    Samir
  11. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Cheers M8
  12. sharkbait
    sharkbait
    I bought a 20 foot component cable from http://www.bluejeanscable.com and would thoroughly recommend both them and their products. The quality is superb.
    I bought it on a recommendation from this forum. I was a bit worried buying from the U.S., but it arrived in 4 days.
    The only thing you have to be aware of is import duty. A bit hit and miss, but you should budget for getting stung.
    I would also say ... if you buy the 7710A, be aware of how thick it is. You could put fires out with that bad-boy. I reckon it's an inch thick easily. It was an issue for me as it was too thick to fit in my wall void. :eek:
  13. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,153
    UK.
    +2,671
    Hi Monster,
    I did the same as you but used some 75ohm double screened BT2003 cable (and the same Maplin connectors by the sounds of it). I needed three 10m lengths for connecting component output of a dvd player to a projector.
    I then compared it with a 5m £5 RGB , and a £33 10m Profigold RGB lead from CPCs, and I couldn't see any difference between any of them. I wonder if I'd notice any difference using a £100 lead, but at that price, I'm not willing to take a chance.
    I did think I saw some extra detail with the Profigold leads, but when I changed back to the cheaper ones, the detail was still there - placebo does tend to make you think you see or hear improvements which aren't really there unfortunately.
    Gary.
