component cable - quick question
Discussion in 'TVs' started by common, Feb 6, 2003.
  1. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    Do they carry audio or just video to a TV ?
  2. MattDX
    MattDX
    I think it's just video.
  3. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    There are probably integrated cables with audio wires too (5 plugs) but regular 3-plug component cables do indeed carry only video.
  4. jim.rae
    jim.rae
    You have three video cables which carry the pictures and two separate cables which carry the stereo sound...
    Good quality phono plugs are the usual way of making the connections.
  5. nathan_silly
    nathan_silly
    Yes, just for video. They are normally 75 Ohm coaxial cable, can either be terminated with phono's, or the higher quality BNC's (true 75 Ohm impedance)
    Normally the BNC's are found on more expensive kit, ie Tag DVD32R, and a CRT Front Projector.
    Because of the impedance, you can use longer cables than S-Video.
    Nathan
