Component Cable for Xbox?
Jon Weaver
I know that this post should go in the video games section, but I doubt if many people in that forum use Component.
I have never been interested in putting my video games on a big screen.. But having just bought a Plamsa, but as the Xbox support Progressive Scan, as does the Plasma, it would be stupid not to try it out
Is there anywhere that sells a 'cheap' component cable? I don't want to spend too much, as its only going to be for occasional use.
I have done a search and found that Comet to a "SAITEK COMPONENT SCART" for £9.99.. But I want it presented on Phonos instead of SCART.. I know it would be easy to convert the cable, but it would be nice to find the proper thing.
Any info on this would be appreciated
Jon
Jon Weaver
If the Xbox had phono based component output then you are right.
But the Xbox has a proprietary AV connector at the back.. You have to buy a cable to bring out RGB, Component, SVideo or whatever from this connector.
CarlB
I got the official Hi-Def (component + digital out) pack when I was in the US earlier this year. Check www.tronixweb.com as I think they sell the same kit.
Works like a charm, great picture with games.
codlord
Jon,
I think you will find the "SAITEK COMPONENT SCART" is not component, only scart or composite video phono.
Have you got a unmodded UK PAL Xbox? The reason I ask is I was under the impression that Progressive scan was not enabled on uk boxes.
You can apparently use the High Definition AV Pack available from a few places I have found but from what I have read it will not do any prog scan or hi-res stuff on a uk box:
http://www.yorvik-consoles.freeserve.co.uk/xbox/main.html
http://www.mx2.org/acatalog/MX2_org_Xbox_Hardware_210.html
http://www.tqgames.co.uk/hardware.shtm
(not ordered from any of these so can't say how good they are).
Also when I was last in my local 'Game' store, I am sure they had a proper (phono) component cable set for xbox. I can't find anything on their web site but may be worth checking if you have a store near you.
Jon Weaver
My Xbox is as mod'd as it can be.
Its got an Extender chip which can be switched on/off, but is running the EvolutionX BIOS from the 'onboard' BIOS.
It also got an 80gig hard-drive installed, which means I can run all my games straight from the HD.
I am not use whether the modified BIOSs that I am running will allow Progressive Scan, but they enable everything else, so I imagine so.
Don't know about DVD playback, but I am sure that Progressive is an option games.
Joe Fernand
AVForums Sponsor
Jon
As per Codlords post you can pick up the 'Gamester' High Def pack from Game for around £25-£30 (from memory) - it maybe gives you more than you require though.
It has a breakout box and then:
1 x set of three RCA to RCA for Component video
1 x S-Video cable
1 x TOSS link digital audio cable
1 x set of two RCA to RCA for analogue audio.
Best regards
Joe
Jon Weaver
Thanks for the info.. I will pop into town later and see if my local 'game' has one.. However, I have a feeling that I am going to get a blank look and an attempt to sell me a normal AV cable, as "its got 3 phonos, so it must be the same"
I found one on-line in the end for £8.99, but they charge handling, VAT and shipping and the cost soon mounts up.
whistlingDogg
which plasma did you get in the end>
Jon Weaver
Toshiba 42PW27 (Panasonic Series 5)..
But its killing me, as its still in the box.. Don't have a stand (yet) and can't take the risk of balancing it temporarily.
Hopefully will have the stand this week.
M
mikeq
Jon: just been into Game in Edinburgh for an Advanced SCART (19.99 if anyone needs to know) and they had the High Def pack for 24.99.
Jon Weaver
Thanks for that.. I poped into Game in Newport and predictably I got a blank look when I asked for 'component'.
I explained what I was looking for and they showed me the normal AV cable.. After all, it had Phonos on it, so it must be the same.
Fortunatly, I spotted the 'High Def' pack (£24.99) on the rack and showed him the error of his ways.
But, for £24.99, I decided to buy the one 'on-line' for a total of £12.99 (including shipping and handling).
Many thanks for your help
Jon
whistlingDogg
Jon
where did you order it from? i was going to get the official one from dvdboxoffice for £17.
Jon Weaver
Try 'www.videogamecompany.com'.
They list it as £8.99, but you have to add a handling fee (£1.50), VAT and shipping.
It worked out at about 12.99
Jon
