Component Cable Box + Playstation 3 + Toshiba 37" Regza + Denon AVR-588 = SAD PANDA
Discussion in 'AV Receivers & Amplifiers' started by artificer88, Jun 17, 2008.
Tags:
  1. artificer88
    artificer88
    Jun 17, 2008
    Instead of spending money for audio I most likely will not detect, I decided to jerry-rig a setup. I have removed all audio/visual plugins from my receiver and connected them straight to the TV and then sent a lone optical cable from the TV's out to the receiver's in.
    Figured it would be that easy, set it to optical, and then be done... but for some reason, it does not want to make it that easy.
    Overview:
    Nintendo Wii plugged into TV via Component AV
    Playstation 3 plugged into TV via HDMI
    Cable Box plugged into TV via Component AV
    TV Plugged into AVR-588 via Optical
    No sound.
    Anyone know any solutions? Thanks.
