Component Board
Discussion in 'Plasma TVs' started by philp_i, Aug 3, 2005.
  1. philp_i
    philp_i
    Aug 1, 2005
    92
    Im looking for a component terminal board for my PW6 Plasma could anyone tell me where to get one from and how much these cost?
  2. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  3. philp_i
    philp_i
    Aug 1, 2005
    92
    Hi Mep, can i just thankyou for all your help in setting my tv up, is this the right terminal board i need, as in the instruction manual for the tv it has a different model number for the component terminal board?
    Just making sure before i order it as its £65 cheaper from here
    thanks
  4. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
    thanks mate, there are two types the bnc connection and the rca connection (this i sprobably the board referred to in your manual TY42TM6Z)......the bnc is cheaper because its from panny commercial as opposed to panny consumer division......if you dont have rca to bnc component cable you will also need to add some rca to bnc adapters to the screen end of the cable but these are only about a fiver and also sold by av sales.
  5. philp_i
    philp_i
    Aug 1, 2005
    92
    Cheers im ordering it now, im just trying to find the rca to bcn adapter from av sales, with no luck at the monent,lol
  6. Mep
    Mep
    Dec 25, 2004
    9,532
    +468
  7. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Ebuyer sell the BNC component terminal board for about £65...which is nice :)
    Clicky
  8. philp_i
    philp_i
    Aug 1, 2005
    92
    i can only see a composite one, is that right? or am i just missing the component one?
    thanks
  9. ReHaBWales
    ReHaBWales
    Jan 7, 2003
    112
    16
    Nope, Your right mate ..they don't seem to have any left :(
    I bought one from there ...a while ago.
  10. blair
    blair
  11. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,735
    Norwich
    +626
    I have to say I bought a 5m one of the Maplin ones as I wanted the BNC connectors and the cable is very good, in fact I swapped the van damme cable I had for my xbox to projector to this as it seemed to be better.
  12. blueshard
    blueshard
    May 28, 2005
    19
    Or do what I've done and get some Thor RCA-BNC leads, so you don't need the adaptors - £25.85 for 1.5m at www.letsautomate.com. I have nothing to compare them to but I have no complaints on PQ - in fact I'd be interested if anyone did have an informed comment.
    One other point - if your PW6 is on a pedestal stand then you'd need to check how much space there is below the board terminals before the presence of the stand means the cable has to bend sharply away. This tends to limit the overall length of the plug that can be accommodated, and with my set-up (PWD7 + TYST42PA20) I suspect that with adaptors on the end I wouldn't actually be able to get the plugs into the board.
  13. tetrarch
    tetrarch
    Jan 20, 2005
    60
    When I set up my screen I had the quintro and scart set-up, but cabled-up with a BNC to RCA cable embedded in the wall.
    I am sorry to appear dim but what are the other two plugs for, I assume that they are "sound plugs" and are redundant if you use a separate amp/surround sound.
    Have I got that right ?
    Regards
    Tet
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    there are 3 for video Y Pb Pr and 2 for stereo sound L + R
    so on BNC board there are 3 BNC and 2 RCA (audio) and on RCA board 5 RCA (3 video 2 audio)
